Multifunction DAQ
Accuracy of NI USB-6361
I have a question regarding the two same DAQ cards having different interfaces.
Does the accuracy of AI & AO channels of NI USB-6361 the same as NI PCIe-6361?
Thanks.
(3,741 Views)
Hi Nisar,
The only real difference between the two cards is the form factor, as in one being a PXIe card and the other one is an USB device. They have the same accuracy.
If you are interested in other specs, take a look at the spec sheet. Unless indicated otherwise, it applies to both.
Ren H.
Applications Engineering
(3,723 Views)
Hi Ren,
Thanks for the confirmation.
Nisar
Asst. Manager
Embedded Engineering Dept
AKSA solutions development services..
(3,710 Views)
