Machine Vision
webcam labview
Hi!
I wanna do a live streaming of a webcam with LabView. I've been told to use NI-IMAQ but...the only one I found requires a Vision Assistant 7.1... so my qestions are:
1. Can I find a FREE (not a trial) IVISION with the minimum requirements to help me?
2. Can I find a LabView with the IVision included? (I have a LabView 8.0)
3. If I can't afford a IVision...can I still fisnish the project with the webcam?
4. Who can Send me an exemple of a project like that???
Thank you!
Message 1 of 14
(10,557 Views)
it depends on what your project's focus, if you are looking for R B G differential, NI has a set of picture control VIs to support this solution. althought ,IMAQ USB toolkit is free, but it need Vision development toolkit to support, if you don't have Vision License, you can use CapX activeX for video capture or just search this website for such as toolkit.
Message 2 of 14
(10,556 Views)
My project is a surveillance camera with live streaming in html...but using LabView...
And this CapX si also a driver like imaq??? do I get some quality in the image?
Message 3 of 14
(10,555 Views)
Oh YEAH, From your mentioned, the CapX is perfect for you, it is surveillance driver.
Message 4 of 14
(10,552 Views)
I have trouble finding it! Can u give me a link?
Message 5 of 14
(10,549 Views)
HI, I give you the OCX and develop instruction. it is very easy use.
Message 6 of 14
(10,547 Views)
TNX!
I'll get back with a report when it's done! (now I have to go)
Bye!
Message 7 of 14
(10,544 Views)
It may be easy to use for you...I don't get it!
This is the first time that I used LabView (I'm more into OrCAD and Proteus) and I'm stuck!
Don't you know a site with some examples fot this kind of application? Or ar least a step-by-step-idiot's guide!!! :-s
Please HELP!
Message 8 of 14
(10,520 Views)
Accepted by snuk
Hi snuk,
To use a webcam with LabVIEW, you will need the IMAQ for USB Cameras driver, which  has the following requirements:
- Windows Microsoft Windows Vista/Vista x64/XP/2000  (English, Italian, Japanese, French, Italian, Norwegian, Dutch, Spanish/Portuguese, Russian, or simple Chinese).
- LabVIEW 7.0 or later.
- Vision Development Module 7.1 or later
- NI Vision Acquisition Software 7.1 or later, for USB LabVIEW support.
- Vision Assistant 7.1 or later, for  USB Vision Assistant plug-in module support.
- Vision Assistant 8.0 or later, for USB Express VI support.
 There are examples on the NI DeveloperZone Community, but you will need the above requirements to run the examples.  Here is a link to one of the examples:
 NI-IMAQ for USB: Grab and Save Image with USB Camera
I hope this helps!
Kristen H.
Message 9 of 14
(10,493 Views)
TNX done it!
Message 10 of 14
(10,486 Views)
