If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
07-03-2009 02:04 AM
Hi!
I wanna do a live streaming of a webcam with LabView. I've been told to use NI-IMAQ but...the only one I found requires a Vision Assistant 7.1... so my qestions are:
1. Can I find a FREE (not a trial) IVISION with the minimum requirements to help me?
2. Can I find a LabView with the IVision included? (I have a LabView 8.0)
3. If I can't afford a IVision...can I still fisnish the project with the webcam?
4. Who can Send me an exemple of a project like that???
Thank you!
07-03-2009 02:23 AM
it depends on what your project's focus, if you are looking for R B G differential, NI has a set of picture control VIs to support this solution. althought ,IMAQ USB toolkit is free, but it need Vision development toolkit to support, if you don't have Vision License, you can use CapX activeX for video capture or just search this website for such as toolkit.
07-03-2009 02:28 AM
My project is a surveillance camera with live streaming in html...but using LabView...
And this CapX si also a driver like imaq??? do I get some quality in the image?
07-03-2009 02:49 AM
Oh YEAH, From your mentioned, the CapX is perfect for you, it is surveillance driver.
07-03-2009 02:59 AM
07-03-2009 03:15 AM
07-03-2009 03:39 AM
TNX!
I'll get back with a report when it's done! (now I have to go)
Bye!
07-03-2009 10:13 AM
It may be easy to use for you...I don't get it!
This is the first time that I used LabView (I'm more into OrCAD and Proteus) and I'm stuck!
Don't you know a site with some examples fot this kind of application? Or ar least a step-by-step-idiot's guide!!! :-s
Please HELP!
07-06-2009
10:06 AM
- last edited on
04-01-2025
09:20 AM
by
Content Cleaner
Hi snuk,
To use a webcam with LabVIEW, you will need the IMAQ for USB Cameras driver, which has the following requirements:
- Windows Microsoft Windows Vista/Vista x64/XP/2000 (English, Italian, Japanese, French, Italian, Norwegian, Dutch, Spanish/Portuguese, Russian, or simple Chinese).
- LabVIEW 7.0 or later.
- Vision Development Module 7.1 or later
- NI Vision Acquisition Software 7.1 or later, for USB LabVIEW support.
- Vision Assistant 7.1 or later, for USB Vision Assistant plug-in module support.
- Vision Assistant 8.0 or later, for USB Express VI support.
There are examples on the NI DeveloperZone Community, but you will need the above requirements to run the examples. Here is a link to one of the examples:
NI-IMAQ for USB: Grab and Save Image with USB Camera
I hope this helps!
Kristen H.
07-06-2009 11:19 AM
