Machine Vision
To detect USB webcam
Hi, I am trying to detect USB webcam using NI Vision Assistant but its not works ! I already installed requisite drivers for it though its not possible to acquire images using webcam.
(5,136 Views)
Hi
Its possible to acquire image from web camera. What kind of camera are you using is it direct show compatible? Are you installed IMAQ USB Acquire driver?
Silver_Shaper | CLD
(5,130 Views)
Hi !
      Yes, I have installed IMAQ USB driver. I have windows XP SP3 and I am using Intex USB webcam, its plug & play. I have checked it, by simply double click on it & it open means it shows live images just like we do in online chatting !
(5,127 Views)
Hi
Check your camera is direct show compatible else follow this thread or buy a new camera with compatibility. (Its a mistake from Ni not yours)
Silver_Shaper | CLD
(5,120 Views)
I have checked my webcam. its direct show compatible !
(5,103 Views)
Are you still having issue, if so check this
Silver_Shaper | CLD
(5,086 Views)
f your goal is to work with you ltener vision first note that the programs have a cost, in any case you can use them in mode of assessment and expire over a period of time. You can perform image acquisition only drivers from VAS , but for any treatment or handling or VDM VBAI you need , plus VAS . You can download the evaluation software from the following links :
In this example, we will create a program in Labview to capture images from a USB camera to your application for further processing using the NI Vision module.
https://decibel.ni.com/content/docs/DOC-30531
(4,651 Views)
