Machine Vision
extension board
Hi
I am using a  1429 cameralink board and i try to use the extension board to make a triggerable acquisition on encoders signals in C#.
My programm is working fine when i use RTSI lines...
My question concerns the extension board... Is there somme documentation on it? This device is using DaqMx or IMAQ I/O?
 I cannot see it in MAX
Thanks a lot
(3,957 Views)
This device does not use a driver and will not be seen in MAX. It is only an extension board and can be considered a breakout board or extended cables for the Camera Link I/O lines. The following link is the current manual for the extension board:
NI Camera Link I/O Extension Board (PCIe) User Guide
Vince M
Applications Engineer
(3,935 Views)
So What is the way to generate TTL to this extension or to acquire analog Input.
This device contains AI, AO and TTL....
(3,914 Views)
To generate TTL signals just sent them to the TTL lines of the 1429 and they will be directly routed to the extension board.
This device does not contain AI or AO lines only TTL I/O or in other words DIO.
Vince M
(3,879 Views)
