Machine Vision
Particle Filter 3 unexpected behavior
I'm passing a binary image to Particle Filter 3.vi and attempting to filter out all particles that do not fall within a net area criteria. I set the filter settings as follows:
Measurement Parameter = Area
Connectivity = True (8)
Range Lower Value = 200
Range Upper Value =400
Range = False (include)
Measurement Type = pixels
Keep/Remove Particles = False (keep)
When I pass the resulting filtered image to the particle analysis report.vi. I get Many particles whose area is less than Range Lower Value (200).  What am I doing wrong?
(3,645 Views)
Robicheaux -
That all looks reasonable - can you post your code and your sample image?
Greg Stoll
Vision R&D
Greg Stoll
LabVIEW R&D
(3,621 Views)
Found the problem.  I deleted the selection value cluster control and re-created a new control.  Everything works as expected now.  The original control was created by right clicking on the select value terminal but I'd copied it to several different locations, must have somehow gotten corrupted.
(3,610 Views)
