Machine Vision
Showing results forĀ
Search instead forĀ
Did you mean:Ā
Finding center and angle
@muks wrote:
@Butterworth wrote:
@Meisspa wrote:
Hi Butterworth,
try to implement a counter for measuring the cycle-time for one image acquisition and processing. (http://digital.ni.com/public.nsf/allkb/6F6B9F4E149C80578625652800784764) Then you can estimate the theoretical possible frames per second. What type of camera you use? Basler Ace? I donĀ“t know what exactly you want to do, but the camera is relativly fast (exposure time), taking photos of falling objects - of course you need enough light- is no problem for this entry-level camera. But the number of frames per second is limited.
Paul
Hi Meisspa, my camera is Basler ace2500-14gc. I will use cycle-time measurement tool that you said. My project is finding the parameters in attached  image.
the scope now looks different
Hi muks. What do you mean by that?
Message 11 of 47
(4,044 Views)
The requirement of both these images are different
Message 12 of 47
(4,044 Views)
So what must be done sir?
Message 13 of 47
(4,039 Views)
Accepted by Butterworth
A little modification in the vi  that i already gave
Message 14 of 47
(4,021 Views)
The above vi will give you X' teta and y as u mentioned. Post a real time camera image if you are stuck
Message 15 of 47
(4,020 Views)
Do you design all VI by yourself or design in Vision Assistance then convert it to VI? Does those two different ways affect the processing time?
Message 16 of 47
(4,002 Views)
I generally use vision assistant to get the initial processing done. The i do it with lv .
Message 17 of 47
(3,997 Views)
Hello again. I need to take real world images with my camera to apply the processing operations that I asked for you before. For example take one frame at every 30 secs. Which way is the less tring and fast for computer?
Message 18 of 47
(3,972 Views)
Can you give an external trigger to your camera?
Message 19 of 47
(3,970 Views)
I dont think there will be any external trigger for now.
Message 20 of 47
(3,966 Views)
