Machine Vision
Convert Bayer Image Array to RGB Image
Hello Everyone,
I am currently working with Live Image of a camera. From our hardware I get raw data and convert it to a bayer array (BGBG). Now I am trying to get the RGB Image from this array using "IMAQ Bayer to RGB". I am using "IMAQ ArrayToImage" to convert my BayerArray to Image. Unfortunately that doesn't work and I get the error: "Error -1074396080 occurred at IMAQ BayerToRGB,Possible reason(s):Invalid image type.
Can anyone help me how to fix this error?
Attached you a screenshot of the BlockDiagram.
Thanks a lot in advanced
Regards
Sinan Ismael
Certified LabVIEW Developer
Germany
Message 1 of 9
(6,036 Views)
Actually you have to define your RGB (destination) image properly  when you create it. To do so, set the "image type" input of the IMAQ Create.vi to RGB32.
Sami
Message 2 of 9
(6,030 Views)
Thanks Sami, I tried that but nothing happened.
Attached you my VI. A TestPattern has to be displayed
Message 3 of 9
(6,007 Views)
Your raw data being U16, you need to :
  1. select image type for the "bayer image" as Grayscale (U16)
  2. select image type for the "RGB" image as RGB (U64). RGB (U32) might wok but make sure data are properly cast.
Sami
Message 4 of 9
(5,988 Views)
Thanks, but it still does not work. There is no error but a complete black image is displayed!
Message 5 of 9
(5,981 Views)
Please move your cursor on the image display pixels : the image looks black but you should see that pixel values are not 0s.
Message 6 of 9
(5,971 Views)
Yes, you are right! I think that is because there is no alpha values (intensity)! Is there a way to display the image without alpha?
Message 7 of 9
(5,969 Views)
Accepted by Sinan_Ismael
The values contained in your image are low if we consider the whole 16bits dynamic range : your highest raw intensity is just above 10bits so it is understandable that on a 16bits scale, they give you "dark" pixels.
I suggest you use "IMAQ Image Bit Depth.vi" to set the real or optimized bit depth for your data. You'll get a much better display.
And my final advice would be : always make the difference between the data and the way you display them !
Message 8 of 9
(5,961 Views)
Thanks a lot. I got it!
Message 9 of 9
(5,905 Views)
