Machine Vision
Angle value in miute and Second format_VBAI
Dear Team,
Is there any direct way to get the value of angle with hour, minute and second format to measure it precisely.
Currently, I am converting into minute value using Formula function in calculator.
But I am wondering to get the value in hour:minute:second format directly to match the result with CMM measurement.
For e.g.  69.95 (calculated value) should be 70:35:00 (Hour:minute:second)
Thank you in advance.
Thanks and regards,
NJ
(2,698 Views)
Hi NJ
Have you tried using :  Inspection Steps/ Use Additional Tools/ Calculator?
(2,437 Views)
Hi Mariana,
Thank you for your reply.
As I have mentioned in my post that I am already converting the value into HH:MM:SS format using calculator.
But here I was wondering if there is some function in VBAI to convert the angle values in HH:MM:SS format directly without using any formula in Calculator tool.
Thanks and Regards,
JN
(2,419 Views)
Hi NJ.
I thought you were counting manually with an external calculator 🙂 Unfortunately there's no such function.
Rina
(2,410 Views)
Thank you for information Mariana.
JN
(2,405 Views)
