Machine Vision
Computer specifications for Machine vision application
Hello everybody,
i want to develop a machine vision application using Vision development module and CVI which enable me the:
-Identification of parts (OCR/barcode/data matrix)
-Dimensional inspection of the parts
-Détection des Défauts
-Presence and Color Inspection of Components
-Verification of homogeneity
my question is :
Does a Core2Duo processor ,4Go RAM PC allow me to do the trick ? Knowing that this application is based on many geometric matching algorithm with its differents match modes and many other technics
thank you in advance
(3,947 Views)
Accepted by Arrouma
Hello/Bonjour Arrouma!
Sounds like an excellent application. We're not computer peripheral experts here, but I can share the minimum requirements for the Vision Development Module and LabWindows/CVI.
LabWindows/CVI: http://www.ni.com/pdf/manuals/374674b.html#SysReqs
Vision Development Module: http://www.ni.com/pdf/manuals/375127b.html#systemrequirements
If your computer meets these requirements, you should be just fine! The next step will be to make sure your hardware is compatible with the computer you're using - if you need help selecting hardware, you should consider calling in to the NI Sales Engineers: (877) 387-0015
I hope this helps! Good luck!
-Derek B
Derek B. (esoDerek)
Product Marketing Engineer
(3,888 Views)
Merci beaucoup Monsieur Smiley Very Happy
(3,877 Views)
