Machine Vision
Computer specifications for Machine vision application
Hello everybody,
i want to develop a machine vision application using Vision development module and CVI which enable me the:
-Identification of parts (OCR/barcode/data matrix)
-Dimensional inspection of the parts
-Détection des Défauts
-Presence and Color Inspection of Components
-Verification of homogeneity
my question is :
Does a Core2Duo processor ,4Go RAM PC allow me to do the trick ? Knowing that this application is based on many geometric matching algorithm with its differents match modes and many other technics
thank you in advance
(4,372 Views)
Accepted by topic author Arrouma
Hello/Bonjour Arrouma!
Sounds like an excellent application. We're not computer peripheral experts here, but I can share the minimum requirements for the Vision Development Module and LabWindows/CVI.
LabWindows/CVI: https://www.ni.com/pdf/manuals/374674b.html#SysReqs
Vision Development Module: https://www.ni.com/pdf/manuals/375127b.html#systemrequirements
If your computer meets these requirements, you should be just fine! The next step will be to make sure your hardware is compatible with the computer you're using - if you need help selecting hardware, you should consider calling in to the NI Sales Engineers: (877) 387-0015
I hope this helps! Good luck!
-Derek B
Derek B. (esoDerek)
Product Marketing Engineer
(4,313 Views)
Merci beaucoup Monsieur Smiley Very Happy
(4,302 Views)
