Lookout
Timer Parameters
I am trying to implement a simple counter that will count the number of times a switch is turned on during a 24 hour, 5 day and 30 day period. I have created timer funtions for this, however, they dont seem to be having the desired result. For the 24 hour, I would like the timer to allow counting between midnights, and reset after every 24 hour. Similarly for the 5 day - monday thru friday. I have enclosed screen grabs for each case, can someone please tell me what I am doing wrong here, and also how to implement a 30 day timer. Any help is appreciated. Thanks.
(3,851 Views)
Use the parameters below and connect these timers to the reset of your Counters.
Time of Day Timer
ON/OFF true
Offset 23:59:59
(resets 1 sec before midnight)
Duration 00:01
Time of Week Timer
ON/OFF true
Offset 23:59:59
(Lookout counts Sunday to Saturday for the week. If you want Monday to Sunday use the listed parameter, if you want Sunday to Monday use 00:00:10, this will reset the time a 10th of a second after midnight Sunday morning.)
Duration 00:01
Time of Month Timer
ON/OFF true
Offset 00:00:10
(To over come the inconstant number of days, use a 10th of a second to have your counter reset first thing on the 1st day of the month.)
Duration 00:01
Hope this helps.
(3,851 Views)
Ollie - that helps a lot.
Field testing it now. Thanks.
Sudhi
(3,851 Views)
