Lookout
Polling RTU's
Can Lookout 6.7.1 display the time that an RTU was last polled in a system? Thank you in advance for your help.
(6,589 Views)
Yes, by using the update data member.  The update member goes low when Lookout sends a request and goes (and remains) high when it receives a reply.  Lots of ways to accomplish this, one example is:
text(now(Modbus1.update), "yyyy-mm-dd hh:mm")
(6,577 Views)
Thank you. I will look into this. If I have any issues, I may be back to ask more questions if that is okay.
(6,574 Views)
so do I just create an expression using the example you gave me? Also, is there an easy way to manually poll a site? Thank you so much for your help.
(6,572 Views)
Accepted by topic author Prana
Yes, an expression object would work.  That would be good if you display it more than one place.  I work mostly with Modbus objects but I think most if not all PLC objects behave the same.  There are two polling writable data members (yellow fields) - pollrate and poll.  pollrate is a time interval and poll is a discrete.  A pushbutton (or any true condition) could be used to poll the device.
(6,558 Views)
Thank you so much. you have been a real big help. You rock.
(6,556 Views)
I hate to ask dumb questions, but by using the Poll data members, is this confirming actual radio communications to an RTU?
(6,547 Views)
