Lookout
Lookout Versions
I am currently running Lookout version 5.0 and version 6.1 on one server. My question is, Can I install version 6.7.1 on a server that is already running version 5.0, compile the source file of 5.0 and rebuild in version 6.7.
Thanks In advance
Message 1 of 10
(4,237 Views)
So do you mean you want to use two versions of Lookout in computer?
Message 2 of 10
(4,211 Views)
Yes.. version 5.0 and Version 6.7.1. Use both until I build new screens in 6.7 then will remove 5.0
Message 3 of 10
(4,195 Views)
Hi, yes, you can use both version 5.0 and Version 6.7.1 on the same computer,  you can create the process using version 5.0 and then build it in 6.7. But you cannot open the two software at the same time.
Message 4 of 10
(4,179 Views)
Thank you for the reply.. I can open and run 5.0 and 6.1 at the same time on my server, Can you tell me what happens when you open 5.0 and 6.7.1 and run together?
Message 5 of 10
(4,172 Views)
It seems that only one version of Lookout can be opened at one time, that means when Lookout 5.0 is opened, you cannot open Lookout 6.7.1, and when you open Lookout 6.7.1, you cannot open Lookout 5.0.
Message 6 of 10
(4,159 Views)
Must be restrictions on operating systems and or hard drive space. I can and do  rum 5.0 and 6.1 now.
I am just trying to verify 6.7 will run with 5.0 without complications
Message 7 of 10
(4,150 Views)
Could you tell me some information of your system and computer configuration?
Message 8 of 10
(4,132 Views)
I am running Server 2003 with multiple hard drives. I can open and leave running 5.0 and 6.1 at the same time with no issues.
Message 9 of 10
(4,128 Views)
Hello, Lookout 6.7.1 can only be supported by Windows Server 2003 R2 (32-bit) and also has the following minimum system requirements:
  • A minimum of 512 MB of RAM. National Instruments recommends 1 GB of RAM.
  • A minimum of 1 GB of free disk space, plus more to store the amount of historical data you intend to log to the Citadel storage system. National Instruments also recommends that you have 1.5 GB of free disk space for file swapping.
  • A minimum screen resolution of 800 x 600 pixels. National Instruments recommends a screen resolution of 1,024 x 768 pixels.
  • Internet Explorer 6 SP1 or later.
I don't know if you OS belongs to R2 edition, if your system can meet the above requirements, you can installed Lookout 6.7.1 in the system.
Generally speaking, the two versions can be intalled in one computer, but not recommended.
Message 10 of 10
(4,118 Views)
