From Saturday, Nov 23rd 7:00 PM CST - Sunday, Nov 24th 7:45 AM CST, ni.com will undergo system upgrades that may result in temporary service interruption.
Lookout
Lookout Discrete Output from Analog Input
I am very new to Lookout.  This may seem like an easy thing to do, but I am not finding out how to output a discrete signal from an analog input signal.  The analog input is a temperature, and if the temperature (or multi inputs) go above a certain value, it should send an output signal to the discrete output channel.  I have been able to create the input and the output, I just don't know how to link them.
Thanks for your time.
(1,471 Views)
Not sure if this answers your question, but if you need Lookout to write a value to a PLC you would use 'edit connections' on the PLC object's writable member (right click for pop-up).
(1,459 Views)
Hello Rkdomer,
Thank you so much for your reply.  It is not quite what I am looking to do.  I am monitoring temperatures and from 1 or more of these temperatures, should it reach a specific value (say 100 °F), how can I connect these high values to activate an output?  What I am looking to do, is to wire the output to an E-Stop panel.  Maybe even easier, can we "connect" alarms such as HiHi to an output?
(1,455 Views)
