in data 02-07-2012 05:25 PM
Upgrading to Lookout V6.6 build 49152 from 5.1. The hypertrends work but the cursor information is always the same and doesnt change when moving the cursor.
in data 02-08-2012 08:46 PM
in data 02-14-2012 12:05 PM
Here is a hypertrend with the cursor in two different positions. The value is 37 for this trend line no matter where the trend is when it is opened. Other trend lines are stuck at different values.
in data 02-17-2012 10:03 AM
I have the same problem, is there a fix for this? I am using version 6.6.
in data 02-26-2013 04:17 PM
We are also seeing this issue, both in 6.5 and 6.6.
in data 02-26-2013 04:24 PM
Looks like you're trending a symbolic link? If so, have you tried trending the data member directly?
in data 02-26-2013 04:40 PM
I just did on ours and it had the same effect. Plus, using a static address defeats the purpose of symbolic links for us.
We actually see a change for other cursors on the same graph, but one or more are only displaying a constant value. The funny things about this are:
in data 12-05-2013 10:48 AM
Also seeing this on 6.7 clients.
in data 12-05-2013 12:40 PM
in data 02-19-2014 03:21 AM
This behavior is caused by corruption of the Citadel data on the server. I have found that restarting the server or simply restarting nicitdl5 will fix the problem, restoring proper cursor values in Hypertrends.
