Lookout
How can I delete alarm and event data from a Citadel5 database
How can I delete alarms and event data from a Citadel5 database? There is a article (ID: 2NNAN9M9) that says how to do it using MAX but when you archive just the alarms and event there is not an option to delete the old data. I do not need the old data i would just like to delete it from the Citadel5 database.
Thank you
(6,434 Views)
This KB helps you to delete the alarms.
If you use DSC 8.5, run this command instead
osql -S computername\Citadel -E -i C:\delete_cmd.txt
computername is the name of your computer.
Ryan Shi
(6,414 Views)
Ryan,
It would be really nice if you could put together a working Lookout 6.5+ citadel control example (with all the proper syntax) to perform these deletions.
Ed
(4,482 Views)
