LabWindows/CVI
CVI encryption support
Add samples/dotnet/mscorlib.fp to your project, and #include "mscorlib.h" in your source file. This is the shipping CVI generated wrapper for the .NET core runtime engine (mscorlib) assembly, which contains all the above objects.
Message 11 of 19
(2,907 Views)
Jippi!!!
That actually works!! Thanks a lot!!
Smiley Very Happy
Message 12 of 19
(2,901 Views)
May I know how to decrypt a encrypted file, which using DES algorithm?
Here are my coding, got error when create the DES service provider.
    System_IO_MemoryStream__Create_2 (&ms, (unsigned char *)input, 15920, NULL);
    System_IO_MemoryStream_WriteTo (ms, stream, NULL);
    err = System_Security_Cryptography_DESCryptoServiceProvider__Create(&des, NULL);
    err = System_Security_Cryptography_DESCryptoServiceProvider_Set_Key(des, key, 13, NULL);
    err = System_Security_Cryptography_DESCryptoServiceProvider_CreateDecryptor_1(des, &transform, NULL);
    err = System_Security_Cryptography_CryptoStream__Create(&cs, stream, transform, 0x0, NULL);
    System_Security_Cryptography_CryptoStream_Read (cs, &output, &x, 0, 15920, &outputLen, NULL);
Message 13 of 19
(2,554 Views)
Hi moonlotus,
Did this produce a specific error code and/or message along with it?  Having that could be helpful in resolving the issue.  Also, just to clarify, are these functions that you have written yourself, or are they from a library?  Thanks!
Taylor G.
Product Support Engineer
www.ni.com/support
Message 14 of 19
(2,517 Views)
These functions are from .NET library, I import "mscorlib.h".
I get error = -6571, which refers to
CDotNetInvocationTargetError
The target invoked by the LabWindows/CVI .NET Library threw an exception.
(source:http://zone.ni.com/reference/en-XX/help/370051H-01/cvi/cvidotnet_library_error/)
I can't find other example which is availabe in CVI, thus refering the coding from MSDN, DESCryptoServiceProvider
http://msdn.microsoft.com/en-us/library/system.security.cryptography.descryptoserviceprovider%28v=vs...
Message 15 of 19
(2,513 Views)
Hi moonlotus,
Is this error definitely coming from the create step in your code, or is this the final value of "err" after execution?  One thing you could try, if you look at the function panel for the System_Security_Cryptography_DESCryptoServiceProvider__Create() function, if you declare an Exception Handle, rather than using NULL, you can get more information from the exception that is thrown by using the CDotNetGetExceptionInfo() function.  If you right-click on the Exception Handle in the function panel, you can see more information about to do this.  Hope this helps!
Taylor G.
www.ni.com/support
Message 16 of 19
(2,473 Views)
Thanks for your reply.
May I know where can I find the Crypt32.Lib? I'm using CVI 9.0.
Message 17 of 19
(2,426 Views)
It should be found in c:\program files\National Instruments\CVIxx\sdk\lib folder; I don't know if this library is included in every CVI distribution.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
Message 18 of 19
(2,416 Views)
I'm using CVI 9.0, but I do not have this file.
I got it after installing Microsoft Platform SDK.
Thanks.
Message 19 of 19
(2,396 Views)
