LabWindows/CVI
PlotStripChart
Hopefully there is a quick s9olution to this -- it is not obvious.
I am writing a single array of data to a strip chart using PlotStripChart().  The array is larger than the number of displayed points, so it writes all of the array into the control memory.  Problem is, it does not scroll to the far riight, it stays at the left.  I have to enable scroll mode, to get to the far right.
Is there a way to programmatically force the display to the far right of the data in the control memory?
(3,183 Views)
Hendra,
How big is the data set you are inputting to the plot strip chart, and what are all of the parameters you are sending to it?
Kyle Mozdzyn
Applications Engineering
Kyle M.
(3,171 Views)
