‎04-07-2010 03:03 AM
lavalava wrote:Here ya go, take a look at my changes to your codes. I got all 3 of them to running at about the same resource based on what I told you in the last post (all 0% CPU consumption, before was 6% for xcontrol case). Keep in mind, I'm running Vista x64, Intel Quadcore 45nm, that's 4 processors running at 3.65Ghz ea, & 8GB RAM. Even if you have a slower system, you should still see a whole lot better performance than before.
If it wasn't for Vista, I'd be jealous right now!
Shane.
‎04-07-2010 03:10 AM
‎04-07-2010 03:12 AM
‎04-10-2010 05:55 PM
hi lavalava,
finally I found the time to look at the posts. I checked out your solution and was a bit surprised, that it really had quite less cpu load. Then I tried the solution I posted first again and it was as fast as yours. Hmmm, I don't have to understand everything.
But still, both XControls are about 10 times more cpu-consuming then the queue/subvi-approach.
I guess I have to accept, that xcontrols are slow and IMHO not thought through completely (yet).
soranito
