SPARTAN 3E
Without must knowledge, I started with Spartan 3E board
Goal : weighing bridge simulator with serial intefrace and own protocol.
- Rotate knob for simulating weight change
- Serial interface with custom protocol ( PC appli pulls weight for simulator by serial protocol )
- LCD on board to display actual weight
- LED indicating 'stable weight'
- LED indicating 'Weight pulled by serial host'
At this moment I'm strugling with LCD interface
Any basic example available for LCD control of Spartan?
NI: can you make a 'spartan sub map??'
Koen
(3,891 Views)
I have be looking for the 4 data lines on the lcd.
It seems that these go via StraFlash.
But these lines are not simple booleans.
Anybody any idea??
Koen
(3,870 Views)
Dear Mister Algoet,
There is a document which is actually a training session on how to use LV FPGA with the Spartan 3E board.
The following link might also be useful, this is from a lab in a Belgian school that uses the SPARTAN 3E Board with LV FPGA and uses the LCD screens as well.
Many Thanks
Message Edited by Bart De Rouck on 07-15-2008 10:59 AM
(3,847 Views)
Dear Mr Bart
Thanks for the info.
I found a perfect sample in the NI examples.
Thanks also for the info!
Koen
(3,804 Views)
Dear Bart De Rouck
Thanks you for the links
(3,454 Views)
