cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
visa
Resolvido!
Ir para a solução
in the below attached image what is the meaning of icon which is in dropdown list beside com1 com5 & lpt1
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Mensagem 1 de 6
2.995Exibições
     You mean "refresh"??Sorry I accedently pressed me too button.
Thanks as kudos only:)
Mensagem 2 de 6
2.989Exibições
No above refresh & on the corner of COM1, COM2 & LPT1....... That green color icon is there. What is the meaning of that green color icon
--Ranjeet
Mensagem 3 de 6
2.976Exibições
HI,
The symbol means that the VISA resource is still open - ie the COM port is still in use. You'll need to close the port before you can use it again.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
Mensagem 4 de 6
2.971Exibições
Solução
Aceita pelo autor do tópico Ranjeet_Singh
Yes...If the ports are idle then no such symbol can be seen.Just check it out.
Mensagem 5 de 6
2.968Exibições
Thanks a lot guys............
--Ranjeet
Mensagem 6 de 6
2.954Exibições
