unable clean up selection
Yes it works perfectly, it is an internal problem for this VI.
Message 11 of 26
(1,619 Views)
As you have quite many sequence structures in the code (which is NOT recommended btw), i find it possible that someone configured these as "Exclude from Diagram Cleanup".
Please check if this option was set.
Norbert
Norbert
Expert: Geometry
Message 12 of 26
(1,615 Views)
I checked also this option. Nothing is excluded from the clean up.
Zied
Message 13 of 26
(1,607 Views)
What happens if you copy the whole block diagram into a new VI?
Norbert
Expert: Geometry
Message 14 of 26
(1,605 Views)
I tried that as well, but nothing is pasted in the new VI.
Message 15 of 26
(1,596 Views)
If you press Ctrl+a in the original VI, what does the selection show?
Somehow i got the feeling you got fooled by a screenshot of code in the block diagram....
Norbert
Norbert
Expert: Geometry
Message 16 of 26
(1,594 Views)
Norbert
I think the same...
@ziedhosni: Download the attached VI and check it out yourself, is your block diagram behaves like a 'Pseudo Code'...??
Actual and Pseudo Codes
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 17 of 26
(1,583 Views)
I tried to copy paste the actual code in a new VI  and Then I used the clean up tool, I got this picture below,but when I tried to put the actual code in the VI where the clean up is disabled, I got the pseudo code which is the same as the actual code. Is this what you want me to do?
Message 18 of 26
(1,573 Views)
here is the picture
Message 19 of 26
(1,572 Views)
My intention to share that code (Actual and Pseudo Codes.vi) was to illustrate what Norbert_B has suggested:
If you open the code I shared in previous reply and try to select and drag any node/wire in the Actual code and then do the same in the Pseudo code, you will find the difference in actual LabVIEW code and Pseudo code (picture/snapshot of the same).
Message 20 of 26
(1,538 Views)
