unable clean up selection
ziedhosni
Active Participant
Re: unable clean up selection
Yes it works perfectly, it is an internal problem for this VI.
Norbert_B
Proven Zealot
As you have quite many sequence structures in the code (which is NOT recommended btw), i find it possible that someone configured these as "Exclude from Diagram Cleanup".
Please check if this option was set.
Norbert
Norbert
Expert: Geometry
ziedhosni
Active Participant
I checked also this option. Nothing is excluded from the clean up.
Zied
Norbert_B
Proven Zealot
What happens if you copy the whole block diagram into a new VI?
Norbert
Expert: Geometry
ziedhosni
Active Participant
I tried that as well, but nothing is pasted in the new VI.
Norbert_B
Proven Zealot
If you press Ctrl+a in the original VI, what does the selection show?
Somehow i got the feeling you got fooled by a screenshot of code in the block diagram....
Norbert
Norbert
Expert: Geometry
moderator1983
Active Participant
Message contains an image Message contains an attachment
Norbert
I think the same...
@ziedhosni: Download the attached VI and check it out yourself, is your block diagram behaves like a 'Pseudo Code'...??
Actual and Pseudo Codes
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Highlighted
ziedhosni
Active Participant
I tried to copy paste the actual code in a new VI  and Then I used the clean up tool, I got this picture below,but when I tried to put the actual code in the VI where the clean up is disabled, I got the pseudo code which is the same as the actual code. Is this what you want me to do?
ziedhosni
Active Participant
here is the picture
moderator1983
Active Participant
My intention to share that code (Actual and Pseudo Codes.vi) was to illustrate what Norbert_B has suggested:
If you open the code I shared in previous reply and try to select and drag any node/wire in the Actual code and then do the same in the Pseudo code, you will find the difference in actual LabVIEW code and Pseudo code (picture/snapshot of the same).
