template controls
I am looking for an option like template in C++ where I create one template control let's say ring, use it in a VI and calling this VI with different rings(rings with different data entered). While I tried on my own way, but not getting the result. I hope this could be possbile with labview.
Please do let me know any techniques available if anybody has worked on such things earlier.
Thanks in Advance,
Vivek
Message 1 of 10
(5,446 Views)
you may be able to use a cluster with different data types in it
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 10
(5,443 Views)
here is a picture of a cluster:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 3 of 10
(5,437 Views)
Thanks Harold for your suggestion.
Actually, my requirement is like my Vi input should be capable of giving the text of any ring connected to it. I dont' know how many possibilities of rings could be, otherwise  i could have tried cluster. That is why I am looking for something in the template side which could help me in achieving the design. Template in C++ ceates generic data type so runtime properties of data type is passed to it.
I hope such activities is also possible in labview.
Vivek
Message 4 of 10
(5,426 Views)
Hi Vivek,
You can save the ring in a VI as a Control (.ctl) in LabVIEW. Place a ring in a VI & rt-click >> Advanced >> Customize... It ll get opened in the Control Editor. There you can choose what type of Control [such as Control, Trpedef, Strict Typedef] you wish to save it to be used across many VIs.
Try this out. Hope this helps...
- Partha ( CLD until Oct 2027 🙂 )
Message 5 of 10
(5,405 Views)
Forgot to mention...
During run-time, you need to pass the varying set of strings to the Strings[] property of the ring using the property node.
Message 6 of 10
(5,404 Views)
hmmm I understand what a template is I use C++ alot.
you want to use a ring control to pass several different types of types.
which is what a template does in C++ so that you do not need to make several different types of the same data.
I will look into it:)
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 7 of 10
(5,401 Views)
Accepted by vivekkde
this thread may help:
http://forums.ni.com/ni/board/message?board.id=170&message.id=176208&query.id=165237#M176208
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 8 of 10
(5,395 Views)
Thank you Karold!
Really an eye-opener.
Message 9 of 10
(5,382 Views)
Aaha !!!! One more time discussion forum helped me ......
Thanks A Zeal To Harold !!!!
Cheers 🙂
Message 10 of 10
(5,374 Views)
