tektronics- wave form single trigger
Why do you keep referring to your pictures as VIs?  They aren't.  Anyway, look for a VI named something like "read single waveform".  This is the thread I was looking at:
http://forums.ni.com/t5/LabVIEW/TDS5034/td-p/711688
I had to dig around for that one.  Hope it helps!
Bill
CLD
(Mid-Level minion.)
Message 11 of 14
(893 Views)
Accepted by tian66
After I look at the read the single waveform, I found the trick how to do the "single" to keep the triggered rising edge on the screen.
Press the single on the oscilloscope and  then use the initiate.vi which is in the "Low levle" category in the drivers but not the initiate.vi at the top of the driver tree.
The oscilloscople will do the single -> stop ->single -> stop->........
Cheers!
Message 12 of 14
(872 Views)
There is an initialize function at the top level and it is not at all the same thing as initiate (which I said you need to use).
Message 13 of 14
(868 Views)
Yes, you are right. I have it in my program now. The trick here is I need press "Single" and after each iteration, the oscilloscope can go back to the " Single" again but not staying at "Run/Stop". Smiley Tongue
Message 14 of 14
(864 Views)
