08-05-2014 10:53 PM
Why do you keep referring to your pictures as VIs? They aren't. Anyway, look for a VI named something like "read single waveform". This is the thread I was looking at:
http://forums.ni.com/t5/LabVIEW/TDS5034/td-p/711688
I had to dig around for that one. Hope it helps!
08-08-2014 11:51 AM
After I look at the read the single waveform, I found the trick how to do the "single" to keep the triggered rising edge on the screen.
Press the single on the oscilloscope and then use the initiate.vi which is in the "Low levle" category in the drivers but not the initiate.vi at the top of the driver tree.
The oscilloscople will do the single -> stop ->single -> stop->........
Cheers!
08-08-2014 12:00 PM
08-08-2014 01:30 PM
Yes, you are right. I have it in my program now. The trick here is I need press "Single" and after each iteration, the oscilloscope can go back to the " Single" again but not staying at "Run/Stop". ![]()
