subvi flashing on screen when called
Hi All,
I have a subVI flashing up on my screen when called even though I have
all options unchecked on the subVI properties box (from the calling
VI). I have a sneaking suspicion it is something obvious. Any ideas?
Greg
Message 1 of 11
(4,573 Views)
In your VI that's calling the subVI, right click on the subVI and look at SubVI Node Setup. You can override the subVI's properties there and have it Show Panel when called.
Message 2 of 11
(4,573 Views)
Another thought;
Goto the hierachy screen.
Do ctrl-f
select objects
right click on select object>>>other>>>breakpoints
do the search.
You may have a break point set.
Ben
Message 3 of 11
(4,573 Views)
Well, I learned something new there with the hierarchy screen at
least. Thanks.
Problem still remains though. No breakpoints found and all options
are unchecked in the subVI properties dialog.
I have 2 graphs in the subVI that flashes. That should not be the
cause though, correct?
Greg
Ben wrote in message news:<506500000005000000B8DC0000-1042324653000@exchange.ni.com>...
> Another thought;
> Do ctrl-f
> select objects
> do the search.
> Ben
Message 4 of 11
(4,573 Views)
Have you checked the show "Front Panel When Called" and "Close Front Panel
When Loaded" check boxes.
Wiebe.
"Greg Cole" wrote in message
news:46107094.0303251042.47987870@posting.google.com...
> least. Thanks.
> Greg
> > Another thought;
> > Do ctrl-f
> > select objects
> > do the search.
> > Ben
Message 5 of 11
(4,573 Views)
it's easy - go to subvi File/VI Properties, choose category "Window appearance", click "Customize..." and uncheck "Show front panel when loaded". Hope it will help you.
Ivan
Message 6 of 11
(4,099 Views)
Ivan
I suspect that after 9 years the user has found the solution to the problem, or probably doesn't care about it anymore.
Message 7 of 11
(4,087 Views)
Yeah, I think so, I didn't notice the date 🙂
Message 8 of 11
(4,082 Views)
I have encountered the same problem, it is annoying. I have tried all the suggestion but doesn't works.
Message 9 of 11
(3,979 Views)
Instead of getting annoyed, attach the main and subVI.
Message 10 of 11
(3,972 Views)
