string indicator scroll to bottom
Hello.  How can I make the string indicator scroll to the bottom of the page using the block diagram?  I have a while loop that process data, each time it finishes an iteration it will dump all the results into the string indicator.  And I would to make it so that it automatically scroll to the bottom of the page at all time. thanks
Message 1 of 13
(26,550 Views)
Accepted by lavalava
If you right click on your string indicator,
go to Create >> Property Node >> Text >> Scroll Position
If your text is updating in a loop, wire it to the number of iterations (see attached)
**Note, you dont have to wire it to iterations. You can wire it to any large number, i just happened to pick iterations.
There is probably a better number to wire it to, but any large number will work (even the timer in my example)
Message Edited by Cory K on 11-06-2008 04:41 PM
Cory K
Message 2 of 13
(26,542 Views)
Connect a very very big number to the scroll position property of your control, it will automaticaly scroll them to the last row.
Message 3 of 13
(26,535 Views)
is the scroll position a property node, I can't seem to find it
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
Message 4 of 13
(24,713 Views)
Property>text>scroll
And if you wire a -1 to it the scroll always goes to the bottom line (like Cory said a -1 is a large # when coerced to unsigned in fact it is THE largest #)
"Should be" isn't "Is" -Jay
Message 5 of 13
(24,688 Views)
You can also use a feedback node.  I'm not sure what the purpose of using the property node is, seems like more work when you can just concat a CR/LF to the string.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 6 of 13
(24,666 Views)
Mo- we were talking about setting the position where the vertical scroll on the FP object is - not what data is in the text
Message 7 of 13
(24,660 Views)
I see.  With your further explanation and re-reading the prior posts, it makes sense.  I misunderstood what the OP was after.
Message 8 of 13
(24,623 Views)
Wiring the infinit symbol to the scrollpos will make sure it is always at the bottom 🙂
Message 9 of 13
(24,620 Views)
Sure will- but I can count to -1Smiley LOL
Message 10 of 13
(24,613 Views)
