strict reference
i am trying to set the value of a control through a property node.  The input type is varient, since the reference passed is not strictly typed.  Is there a way to convert the reference in the example attached to a strictly typed, so that I can passed a boolean, instead of a varient, into the value property?  Thanks!
(9,312 Views)
Accepted by topic author jyang72211
The FP has functions that allow for that.
Change the constan on the diagram to a control.
Get a copy of the boolean (just copy it from where ever it was to start out).
Drop the copy on the same FP as the refnum control.
Do a ctrl-copy of the boolean then drag it into the refnum control and watch cloesly that the refnum will change when you find teh sweet-spot and drop the copy into the refnum control. The refnum will then be a strict of teh type you want.
YOu can toss the copy of the boolaen after you are done.
Ben
(9,308 Views)
Oh, so you can only do it to a control and not a constant.  I see.  Thanks!
(9,296 Views)
Another way to get a constant of a strict type reference is to create a reference to the front panel object, then create a constant from that reference.  Two right-clicks, no dragging things around on the front panel.
(9,286 Views)
I found another way. After changing the reference to control, right click >> select "Include Data Type". This seems to be the simplest way for me.
TailOfGon
Certified LabVIEW Architect 2013
(9,274 Views)
