reset hub
Hi all,
I'm using an ethernet hub to network 2 homemade electronic boards and collect data from them using labview. The boards use udp for communication.
The problem is that each time that I collect data I have to either wait a couple of minutes or unplug the power of the hub in order to collect data again, otherwise it wont work.
any idea how to fix it?
thanks
sbz
Message 1 of 16
(4,958 Views)
Hi sbz,
Could give us some more info including the you have tken to troubleshot? Do you have firewall software installed?
Joe Daily
may the G be with you ....
Message 2 of 16
(4,929 Views)
I'm just trying to figure out how this is a LabVIEW question. This sounds like a hardware problem with the hub. Actually, why would you be using a hub? Hubs are pretty rare these days, as they've been supplanted by switches.
Message 3 of 16
(4,918 Views)
there is no  firewall software installed. and also it is a switch not a hub, sorry.
thx guys
Message 4 of 16
(4,903 Views)
reason that i think its a labview problem is that its possible that the udp close does not close the port when it's networked with 2 instruments. (i have to use udp).
Message 5 of 16
(4,887 Views)
Show us some code!
Are you always using the same port numbers?
How ofter do you close and re-open the ports?
Are both sides LabVIEW based?
Message 6 of 16
(4,876 Views)
yes, im using the same port and close it after each measurement. also both sides is labview based. thx
Message 7 of 16
(4,863 Views)
Why don't you keep the port open for the duration of the run?
Message 8 of 16
(4,859 Views)
labview gives an error that the port is busy.
Message 9 of 16
(4,846 Views)
Gives the error when? Please post your code, as your statements are a little too brief to really convey what you're doing.
Message 10 of 16
(4,840 Views)
