error 2147352567 using Insert form DB Toolkit
I'm getting error when i try to put some data into my database. I can connect to my db and there is no error when i try to get data from tables, but it occures when i use DB Tools Insert Data function.
I tried to find solution on this forum but i failed.
I attach .vi file with my program, and .png with error description
(2,958 Views)
Any chance you could upload a quick screenshot of the code?  I could have a look.  But don't have the correct version of Lv installed to view the VI you attached.
http://www.medicollector.com
(2,932 Views)
No problem, i upload png file with code.
I managed to insert data using Execute Query function so it's just curiosity why my code doesn't work.
However, it would be more usefull to have working Insert Data function ;]
Thanks in advance.
(2,923 Views)
