09-14-2005 06:31 AM
09-14-2005 06:46 AM
09-14-2005 07:15 AM
09-14-2005 07:42 AM
Could you post the subvi (as LV7.0)? I just can't see any reason why it shouldn't work and would like to test it on my system.
09-14-2005 07:55 AM
09-14-2005 08:05 AM
Blog for (mostly LabVIEW) programmers: Tips And Tricks
09-14-2005 08:09 AM
The file "_MotTempAverCheck.vi" does nothing and has nothing to do with the others.
If you want clearer help, you need to ask clearer questions, and provide more correct info.
09-14-2005 08:12 AM
I just had a look at the vi - and I do not see anything that does not work as expected. The messages are also correct.
If your problem still exists, you should explain it better as CoastalMaineBird said.
Thomas
