Increment Table Index
Hi All,
   I am using an event to save data to a spreadsheet file and have it showing on my front panel in a table. What I need to be able to do is append the data into the table each time the event is executed. I can't figure out how to increment the table index. Can anyone please tell me how to increment the index of a table to allow data to be appended to it? Any help would be greatly appreciated...
Charlie
Everything is Free! Until you have to pay for it.
(3,804 Views)
Hi Charlie,
Take a peak at the BuildArray VI, in the following thead (8 or 9 posts down):
http://forums.ni.com/ni/board/message?board.id=170&message.id=142166
If you create a "local" copy of the table (on table, right-click, create-local) you can use it as a data source (right-click,change-to-read), append the row (or col) and write back to the table.
cheers
Message Edited by Dynamik on 09-13-2005 08:57 PM
Message Edited by Dynamik on 09-13-2005 09:01 PM
When they give imbeciles handicap-parking, I won't have so far to walk!
(3,797 Views)
I don't know if this is the problem, but a table is a kind of 2D string array with a few extra attributes. You can use the array functions to deal with them. In this case you need to use the build array function, and wire a 1D array of strings (the new line) into the bottom (of a 2 cell build, just pull it out or add element) and the original table in to the top. This will give a new 2D array of strings with a new line at the bottom. Wire this to a table and you will see the original table with the new line.
Yours SIncerely
John
(3,791 Views)
Hey Dynamik,
   Thanks for the response and I will check the link out. Appreciate your reply!
Thanks, Charlie
(3,773 Views)
Hey John,
   Thanks for the information I will certainly give it a try and see how it work. Thanks for your reply!
Charlie
(3,772 Views)
