"Intelligent" unique array
I have several arrays (grouped inside a cluster) with two columns : header is in the first column, value in the second column.
I want to have an array with only unique headers, and values.
I manage to have unique headers, but the problem is unique data. I've attached the VI. I think the problem may come from "insert into array" which I believe cannot insert on a row that doesn't exists yet?! Can you help me?
Message 1 of 10
(4,799 Views)
finally, with two succesive for loops and a bit of Gcode...
Message 2 of 10
(4,774 Views)
Thanks for posting the solution. Haven't looked at it, but if your problem is solved please accept your post solution.
Message 3 of 10
(4,760 Views)
One problem is that you represent integers as strings, so an alphabetic sorting of the numbers of each row will not be sorted numerically. Do you care about the sort order of the numbers in each row? If not, a variant attribute based solution is especially simple, but with a few minor tweaks in can also be adapted for the numerically sorted case.
Message 4 of 10
(4,757 Views)
Accepted by haha1234
Here's how that could look like.
(To sort the numbers numerically, you could do a "string to numeric--sort--numeric to string" before the lower input of the last "built array". If you would zero-pad the numeric strings so all have the same length, you would not have this problem. Modify as needed).
Message 5 of 10
(4,732 Views)
thank you you all for your contributions.
The values 1, 45, 7... are just examples. They can be string, integer, double, that’s why I used string by default. I don’t care about the order, I just don’t want any blanks.
altenbach, your variant example is very interesting I will study it as I was not aware of this possibility. It seems to be more efficient.
but... imagine I care about the order ? Is there a way to do an alphanumerical sort (just like files in windows folders)? Example 11 before 99 before A1 before B1 before B2 etc...
regards
Message 6 of 10
(4,716 Views)
As Suggested earlier "Variant Attribute" will be the easy way of handling to collect data of specific header, Once its data is collected you can sort the array (wrt. Header) of your choice.
Message 7 of 10
(4,707 Views)
The variant attribute method will always be sorted alphabetically. No extra code needed for your examples. However "11" will be before "2" unless you call it "02"..
Windows explorer (in newer versions of windows!) will do a mixed mode if parts of the file name are numerical. You would need to implement that yourself. I already mentioned where that sorting step would go.
Message 8 of 10
(4,685 Views)
OK I understand.
However, I noticed a small problem. If I have an empty string after the header instead the number, there is an error when the VI tries to set the attribute to the variant.
Is it normal ? Is there a workaround ?
Message 9 of 10
(4,660 Views)
Yes, empty strings are not allowed for attribute names. Simply use a case structure and bypass that code (or just ignore the error)
Message 10 of 10
(4,653 Views)
