problem using ActiveX for excel app to determine row/col no.s
hello,
I would like to develop an app, which would find out the total no. of rows and columns from a given excel sheet and read out the data in the same. I have made use of few vi's I found on forum, but having trouble runing them,
can anyone please suggest me what could I be doing wrong? I have never used activex before...
Now on LabVIEW 10.0 on Win7
Message 1 of 12
(7,959 Views)
What error you are getting, when you are trying to execute it.
Message 2 of 12
(7,951 Views)
Have a look on this example, might help.
http://zone.ni.com/devzone/cda/epd/p/id/3187
Message 3 of 12
(7,949 Views)
Hello Puneet, I am usnig the same example as the link you posted.
I would like to perform foll:
The user would enter data into an excel file and I would like to read the same in labview program. Since the no. of rows and columns of the data file is not fixed, I would liek to find out
the no. of rows and cols first and then read the entire file.
Message 4 of 12
(7,930 Views)
Accepted by topic author LV_Enthu
I would have used the Free Excel Toolkit. See some example with it here, here and here
The library contains premade Excel ActiveX functions. This function right here would have helped you alot:
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 5 of 12
(7,925 Views)
Even Deejay, what about the data in the excel sheet? how to extract that?? I can find the last row and column, ...
Message 6 of 12
(7,906 Views)
Also, i downloaded the toolkit you made, how can i use it? how to install it?
Message 7 of 12
(7,904 Views)
HiSmiley Happy
Yesterday I sent an email to a guy, explaining how to install it. Download the toolkit and the instructions I have attached and you should be fine.
Even
Topro AS
Norway
Message 8 of 12
(7,898 Views)
awesome.. taht helps...
g8 job 🙂
Message 9 of 12
(7,886 Views)
You can also check ou tthe Excel Active X board where many items and examples are avaliable: There is really great stuff in there.
http://forums.ni.com/t5/BreakPoint/Excel-Board/td-p/379682
Tim
GHSP
Message 10 of 12
(7,827 Views)
