NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Trusted Enthusiast
TCPlomp
Excel Board
Hi all,
Is it about time to start a LV-Excel board? :smileyvery-happy:
I have a feeling that some Class courses cover the interaction between LabVIEW and M$Excel, I think 1 out of 2 posts at the LabVIEW board is about communication with LabVIEW and Excel.
So to bundle these questions it might be usefull to dump them in a seperate place!
Ton
My LabVIEW Ideas
Active Participant
Joe_H
Re: Excel Board
I would like to contribute to this board, and say it is about time we created this thread.
Here is a toolset that I have compiled over a period of time working with excel.
Also a tip for beginners:
If you do not know how to do it in excel then you probably will not figure it out in LV either. So my suggestion would be to read the excel help and figure out how to do it. Then record a macro of what you want to do and then duplicate the macro in LV using methods and properties.
Joe.
"NOTHING IS EVER EASY"
Trusted Enthusiast
TiTou
Re: Excel Board
That is quite a sensible piece of advice, I did try to do in LV something that I didn't know how to do in XL and had to give after loosing a couple of hours :smileymad:
Now I try be more humble.
More about the this thread, no doubt that an Excel board would get packed with loads of post quite fast, that's for sure !
And thanks a lot Joe for sharing your code !
________________________________________________________________
"Cambiar el mundo, amigo Sancho, que no es locura ni utopía. sino justicia."
Cervantes
Knight of NI
Knight of NI
tst
Re: Excel Board
I wouldn't count on it. The NI forums have a rather rigid structure which does not support moving posts from board to board. The LV-Excel interaction is by no means significant enough to warrant a whole board. NI apparently doesn't like making big changes and even much more important things don't get a board.
You can either create a thread where links to Excel interaction stuff will be concentrated (like this one) or you can post your examples to the new community site.
___________________
Try to take over the world!
Active Participant
Joe_H
Re: Excel Board
This message talks about freezing panes in excel.
Freeze panes
Joe.
Active Participant
shoneill
Re: Excel Board
Personally, I alays try to link Macros with LV code so that I can get the best of both worlds.
Data processing in LV, Copying, Pasting, graphs and so on in Excel via Macros.
Works for me.
I still wich NI would introduce a text-based ActiveX interface possibility so that ActiveX routines in LV wouldn't take up so much space.....
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Active Participant
Joe_H
Re: Excel Board
Here is another board that talks about page setup in excel
Joe.
Active Participant
Joe_H
Re: Excel Board
I have another VI to add ttothe list. this VI allows you to print a worksheet, view print preview, and select # of copies to print.
Joe.
Active Participant
Joe_H
Re: Excel Board
Here is a discussion where i posted some VI'S that will do a search and replace and a "find"
Here are the VI'S
Joe.
Trusted Enthusiast
TiTou
Re: Excel Board
Just to add to Joe's post, the Replace.llb is now also available in LV 7.1 at the same thread, a couple of post after the LV 8 version :smileywink:
Thanks Joe !
Cervantes
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
