pop up UI
Hi, How to create a simple pop up UI after you run the VI and to have Start, Exit buttons on it. Thank you
(3,721 Views)
Hi Zack,
If you go to the VI properties, you can go to the item : VI apearance.
In there you can select "Dialog box"
Afterwards you can easily add a "OK" and "Cancel" button to the VI and handle the events
If you just want to show a message, there is also a standard VI in LabVIEW which pops up a windows message box
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(3,695 Views)
More info can be found here, here or here
Good luck 😉
Kind regards,
- Bjorn -
(3,692 Views)
Thank you so much for the prompt response, keep up with the excellent customer service.
(3,680 Views)
Accepted by zack65
Zack,
can you put this tread as solved?
and if you liked the answer, think about kudo's 😉
Kind regards,
- Bjorn -
(3,678 Views)
