Example Code
One/Two Button Dialog including Window Title in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
 Overview
Demonstrates how the Three Button Dialog.vi can be used to generate a One/Two Button Dialog where you can change the Window title.
Description
To achieve a Window Title in the Pop Up Box, a three button dialog has to be used as One Button and Two Button do not have this input. To use this as a One Button dialog but to have the functionality to include a window title a Three Button Dialog is used with the two redundant button inputs left blank.
Requirements
LabVIEW 2012 (or compatible)
  1. Run the VI
  2. The program will display a One Button Dialog with a customized window title
Block Diagram of the VI
Many thanks for using the NI forums and I look forward to your reply.
Kind regards
David
National Instruments UK
Comments
VDC
Member
Member
on
Simple but Straight forrward. Helped me in saving some time.
Thanks Alot
sebster
Member
Member
on
This also works if you want a two button dialog wih a window title.
Wire strings to two of the inputs, and a blank string to the third.
