mouse click event
hi guys,
I have a problem with my LabView project. The mouse pointer should be controlled through the EOG. This way a disabled person can be able to operate a computer without needing help. At the moment we are able to control the pointer up and down, right and left but we also need to click on an item. Now we need a VI or something like that to choose an item using voltage supply.
best regards Austrin
(2,991 Views)
Can you describe more about the vi you require?
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,980 Views)
In Windows, you can simulate a click using the Mouse_Event API function and there are numerous example online (such as http://digital.ni.com/public.nsf/allkb/0CC5602FE23E86DA86257350004E1B6A). You can find more examples by searching for things such as "simulate mouse".
___________________
Try to take over the world!
(2,970 Views)
There's a useful document available.
How Can I Programmatically Simulate A Mouse Click?
http://digital.ni.com/public.nsf/allkb/9BB3211F3469623649257360000E272C?OpenDocument
Regards
Ulrich
(2,936 Views)
