ploat a hyperbola
My bad, forgot to save with the default values properly set.  Since I assumed you were ultimately looking to do a little more than plot that specific hyperbola, I gave you a general formula with parameters.
Message 11 of 18
(3,533 Views)
Alain S wrote:
EDIT: Altenbach is better in LV programming and faster in typing than me Smiley Sad
That is a truism that warrents promotion to the LV Proverbs thread.
Ben
Message 12 of 18
(3,520 Views)
Accepted by Kolos
I have forgotten quite a bit about conic sections, but I still know my latus rectum from a hole in the ground.  The points you called A and B are the foci, let's assume they are symmetricly placed on the x axis A=(-f,0) B = (f,0).  The number '3' you used is the length of the transverse axis (minimum distance between the two sections), I'll call that C.  You can convert this to the form I used ax^2 - by^2 = 1 with the following equations: a = (2/C)^2, b = 1/(f^2 - a^2).  The attached vi lets you enter the focal distance (f) and the transverse axis length (C).
Message 13 of 18
(3,507 Views)
OTOH, it would not hurt to be faster in programming and better in typing. 😄
Message 14 of 18
(3,496 Views)
Huh man! Thanks!
Can i somehow plot my A and B point in the same graph?( (-f,0) and (f,0) )
Message 15 of 18
(3,473 Views)
Yes, create a second plot for your xy graph that only contains these two points and has a point style.
Message 16 of 18
(3,464 Views)
I can't do it...
Message 17 of 18
(3,436 Views)
Maybe something like this?   Modify as needed....
Message Edited by altenbach on 07-27-2009 09:16 AM
Message 18 of 18
(3,420 Views)
