play different wav files using case structure
sir,
i am trying to play Morse code .wav file for 3 different characters using a case structure. But i am getting an error of " LabVIEW: (Hex 0x12C5) Could not find the sound file."  can you suggest some solution and I think my VI will play the file continuously. instead can you provide me with some solution so that i plays once for every string input ?
thanks
Message 1 of 11
(4,359 Views)
Hi may,
as soon as I correct the file path for your WAVE files I can play the morse code sounds…
(Error 0x12C5 says "audio file not found"! Did you even read the error description?)
Message 2 of 11
(4,328 Views)
GerdW,
thanks for going through my VI.
I had altered the file path in order to compress it but as soon as i correct the file path it is showing me the error "LabVIEW:  (Hex 0x12CA) Cannot recognize sound format."
i have attached my VI with exact file path.
any solutions?
Message 3 of 11
(4,322 Views)
Your VI and .wav files work just fine for me.
The only thing is the timeout on the Output Sound needs to be larger because it gives a timeout value when it plays the B.wav file.
Message 4 of 11
(4,310 Views)
For me also its working fine. Can you provide the screen shot of the error?
Happy to Wire
Message 5 of 11
(4,292 Views)
For me also its working fine. What is exact problem? can you share any screen shots of the error.
Happy to Wire
Message 6 of 11
(4,291 Views)
here i have attached the screenshot of error that i am getting while i play the vi.
Message 7 of 11
(4,274 Views)
Hi may,
for us your WAV files work fine, but not for you.
So I guess the problem is with your computer…
Message 8 of 11
(4,266 Views)
same error buddy
did u figure it out?
Message 9 of 11
(731 Views)
@Emma21 wrote:
same error buddy
This ancient thread has not seen activity in 8 years and we cannot tell from your picture what you are doing wrong. There are infinite possibilities, for example you string input looks empty, but we cannot see the case for the empty string condition.
Message 10 of 11
(721 Views)
