LabVIEW crash
Hi, I created a LabVIEW install with the package builder.
When I start LabVIEW the applicaties crashes directly after the splash screen. I see no error repport in My Docs or temp folders, only a Application error in the eventviewer.
Wat could be the problem?
OS: Windows 10 22H2 with April updates
Thnx for your reaction!
Faulting application name: LabVIEW.exe, version: 25.1.0.4000, time stamp: 0x6784ece3
Faulting module name: NiLmClientMTDLL.25.0.0f183.dll, version: 0.0.0.0, time stamp: 0x677f4035
Exception code: 0xc0000005
Fault offset: 0x00000000000028cb
Faulting process id: 0x3e24
Faulting application start time: 0x01dbad35aabde79b
Faulting application path: C:\Program Files\National Instruments\LabVIEW 2025\LabVIEW.exe
Faulting module path: C:\Program Files\National Instruments\LabVIEW 2025\resource\NiLmClientMTDLL.25.0.0f183.dll
Report Id: fc0b1f01-a81c-4da2-b162-19f31f4bf1dd
Faulting package full name:
Faulting package-relative application ID:
(1,196 Views)
Accepted by topic author trebke
Certifcate was not added to the TrustedPublisher store, package was not succesfull installed. Run it again and Labview works
(1,177 Views)
