permutations of a 6! numerically
Hi John,
look for the "Application Control" functions palette. "Open VI Reference" and "Call by Reference" might be interesting...
Message 31 of 57
(3,130 Views)
Can recursion be used for this challenge wiht LV 8.2?
Somewhere in there we picked-up the option to share clones but without that option, it may blow-up in LV 8.2 due to a lack of memory.
Ben
Message 32 of 57
(3,108 Views)
What would be wrong with just using a while loop that counts to 1000000. Convert each iteration to a string, filter out any number with [0,7-9], then do a simple search and replace (1=A, 2=B, etc).
Of course, it gives you repeat letters and lengths shorter than 6, but those should be easily filtered as well.
Not elegant or super fast (takes a few seconds to build it to an array, didn't try writing directly to a file), but certainly easy.
Message 33 of 57
(3,090 Views)
Its simple, and the filtering would be straight forward,
its not elegant but that would work.
hmm, nice idea. And it would be easy to see if it worked, run a line count compare to n! for that number and check for repeats and remove.
That might just do it.
I'll give it a go! 😄
Message 34 of 57
(3,078 Views)
Here's a quick modification (LabVIEW 8.0), adapted from this much more complex problem. 😉
Message 35 of 57
(3,072 Views)
... and here is the same using plain strings:
Message 36 of 57
(3,056 Views)
sweet, here's hoping it'll run on LV v8.2 😄
Message 37 of 57
(3,051 Views)
Sorry, down-conversion to 8.0 will get rid of the in-place structure, so the attached 8.0 VI is a bit ugly. To simplify, you can remove the inner while loop without breaking anything.
Here's the string version as a 2009 VI for those who upgraded.
Message 38 of 57
(3,045 Views)
Accepted by John Pierson
Here is a cleaned up 8.0 version:
of course you need to be careful. Don't use very long strings or it will break because of datatype limitations. 😉
Message 39 of 57
(3,038 Views)
yup, that does the job perfectly, can even be expanded for 7, 8 etc... itterations.
does waht i needed and more 😄
now to write to a notpad file 😄
Message 40 of 57
(3,033 Views)
