output string displace
I am using the cmd.exe to read the packet receiver but I just want to data-logger only the number. Please help with the example code.
Thank you
Message 1 of 9
(2,156 Views)
Images are not "code". Please attach your VI with some typical test strings.
Message 2 of 9
(2,150 Views)
VI attached
Message 3 of 9
(2,128 Views)
Your output contains many dozens of numbers. Which one do you want?
Message 4 of 9
(2,114 Views)
Accepted by topic author Transt
You said "packets receiver", but if you want the number after the first equal sign ("packets received"), you can do as follows:
If you want any other number, things gets more complicated, especially if you want to support multiple language settings of the OS. I am not sure if these strings change depending on localization.
Message 5 of 9
(2,108 Views)
I can not find the string abbc, b+?
Message 6 of 9
(2,094 Views)
Thank you I got it, How do I can set to read the Received packets delivered number?
Message 7 of 9
(2,061 Views)
As I said, you just need to be more specific in the search string, e.g. as follows (make sure the number of spaces is correct):
Message 8 of 9
(2,038 Views)
If you are interested in all IPV4 statistics, you might want to create an array of clusters where each cluster is a name and a number.
Message 9 of 9
(2,034 Views)
