needed software packages on cRIO for Multicast UDP
I would like to execute that snippet on a cRIO system:
On a standard Win7 PC it's working, I can send and receive messages with no problem.
But on a cRIO I get an error 54 ("wrong network address"). So what the heck?
The cRIO is set up with those software packages (LV2011SP1):
I want to reduce memory consumption, so didn't choose to install all recommended packages.
I suspect something is missing. Which package part is it?
(2,849 Views)
Accepted by topic author GerdW
I found a solution (or is it a work-around?)...
You have to wire the "network address" input of the UDP-Open function. It seems the cRIO doesn't know it's own IP address:
One more correction: You only must use "String to IP" on the cRIO. When used like shown above it gives error 54 on the PC! Arrrgghhh...
Next solution: Put the StringToIP node inside the ConditionalDiagramDisable structure already in use 🙂
(2,843 Views)
