Start elapsed timer when true / reset when false
All,
I have an elapsed timer that needs to start when a signal is True and keeps on counting.
When this signal is false, I have to reset the elapsed timer and it has to start again from zero when the signal is again true.
I guess this is an easy one, but I can not find how to solve this.
If I please it in a case structure, I cannot reset when case is false.
Thx in advance
(3,494 Views)
Care to share what you have so far?  Are you trying to make this a separate VI?  Or is it in a loop?
Have you looked at the Elapsed Time express VI (in the Timing palette)?  That might do what you want.
The other idea is use use a simple Action Engine.
(3,489 Views)
try this...
(3,479 Views)
