multiple selection in listbox without using ctrl key
HI,
I wanted to know whether it is possible to select multiple items in a listbox without using ctrl key or shift key. I am writing a code for a touch screen application and want to enable the user to select multiple entries in a listbox.
I saw a similar post which had a solution for a tree control. Is it possible to do the same for a listbox control too?
-Pavitra
Message 1 of 23
(19,958 Views)
hi Pavitra,
I have tryed what u want.Selecting no. of values and deselecting in listbox is working but when u delecte last value u want double click on that value
try this VI
Santhosh M
Message 2 of 23
(19,949 Views)
HI Santhosh,
Thanks for the reply.
Unfortunately, I cannot access this VI coz i am working on Labview 8. Is it possible for you to send me this vi as Labview 8 version.
Pavitra
Message 3 of 23
(19,946 Views)
HI
For listbox what you can do it use Symbol (Right click on listbox > Visible Items > Symbols), when user click on any field you can change the symbol of that
So using this you can find which items are selected
Hope this helps
Santosh
Message Edited by SantoshJaiswal on 03-25-2009 07:03 AM
Message 4 of 23
(19,941 Views)
I already tried the symbol option. It isnt working.
Could you send a screen-shot of the code for the VI u posted?
Message 5 of 23
(19,927 Views)
Accepted by pavitrabaxi
i have saved to previous version check zip file
Santhosh M
Message 6 of 23
(19,914 Views)
HI
Please find attached snapshot for symbols
Message 7 of 23
(19,907 Views)
Thanks Santhosh!
Message 8 of 23
(19,904 Views)
This is Santosh
Message 9 of 23
(19,901 Views)
thanks to u as well!
Message 10 of 23
(19,894 Views)
