multi tasking
Hi all,
I have a working vi that currently communicate with a serial port. I would like to expand the capacities and have the program communicates with 3 more serial port and still able to run them independently and in parallel.
I have read other related posts but still had no clues of how it should be done. I know that I have to make many sub vis, but have no idea how to connect them together !
Please advise.
dp
(3,393 Views)
Post what you have so far.
Basically you would take what you've done to communicate through one serial port and duplicate that code 2 more times.
(3,369 Views)
HI Ravens Fan,
Thank you for your quick response. I have thought about duplicating my codes but my current codes is already "overcrowded". And it would be messy if I have to multiply it 3 times more. So I'm looking for a "cleaner" way to to do it. If there is no alternative then I'll have to go that round.
dp
(3,335 Views)
If you have code that you use more than once, make it a subVI.  If you need the multiple copies to be truly independent of each other, then set their properties to be re-entrant.
(3,327 Views)
