modbus installation error
Hello, I'm using Labview 8.6.
When I download (nimodbus.zip from http://zone.ni.com/devzone/cda/epd/p/id/4756 ) and try to install the NI Modbus user lib, I get an error "LabVIEW Base Development System 7.1 is not installed!"
Shall I download and install the "LabVIEW Base Development System 7.1" (http://joule.ni.com/nidu/cds/view/p/id/604/lang/en)?
But I have installed Labview 8.6 !! Is this a problem?
Hans
(3,313 Views)
Just had the same Q yesterday.
Try the linker higher on that page. the "exe" version. It is a self-extracting zip that does the install.
Ben
(3,295 Views)
Hi Ben,
thanks for your response 🙂
If I use the "exe" version, will I get the same modbus VIs (same name?) as from the "msi" version?
This is important for me, because I'm using the msi version and the guy who has the installation problem wants to use my Labview source code...
Hans
(3,278 Views)
Accepted by daHans
Now it's possible to download a .zip file from
and copy the files to the according folders.(without any .exe or .msi file)
Now it works.
Hans
(3,213 Views)
